I'm repairing a rusted out 1/2" galvanized pipe in the wall which went to a spigot for the washing machine. All the connections were pretty seized so I had to cut the pipe. I'm using a dresser compression coupling to connect the old cut pipe to the new installed pipe in a vertical installation. The new section of pipe comes out of the coupling to a tee and continues upward creating an air chamber which is capped. The problem is when I turned on the water to test for leaks the new section of pipe popped out of the dresser coupling. Is this to be expected because the new section was unsecured? Is it a requirement to have both ends secured from movement when using this type of coupling?
