Product Description
Watts Series 70A Hot Water Extender Tempering Valve 3/4" (0215500)
No. 70A furnished in 3/4" size with copper connections. Series 70A Hot Water Extender Tempering Valves Sizes: 1/2" - 3/4", meets various installation requirements. They are available with sweat or threaded connections. Temperature range 120° to 160°F (49° - 71°C). The hydraulically-operated thermostat opens a spring loaded check in the cold water inlet allowing cold water to mix with the hot water. They have unusually high capacity for their size. For example, the 3/4" (20mm) 70A-T used for smaller domestic and residential requirements, passes over 10 gpm (38 lpm) with a 10 psi (70 bar) pressure drop. Maintenance is simple too, as the thermostat is easily removed and replaceable as a unit. Valve bodies are of brass construction that is recognized and required to resist corrosive domestic hot water conditions.
***WARNING*** WATTS HOT WATER EXTENDER TEMPERING VALVES CANNOT BE USED FOR TEMPERING WATER TEMPERATURE AT FIXTURES. SEVERE BODILY INJURY (i.e., SCALDING OR CHILLING) AND/OR DEATH MAY RESULT DEPENDING UPON SYSTEM WATER PRESSURE CHANGES AND/OR SUPPLY WATER TEMPERATURE CHANGES. A.S.S.E. STANDARD 1016 LISTED DEVICES SUCH AS WATTS MODELS L111 OR MMV SHOULD BE USED AT FIXTURES TO PREVENT POSSIBLE INJURY. The Watts Hot Water Temperature Control Valves are designed to be installed at or near the boiler or hot water heater. They are not designed to compensate for system pressure fluctuations and should not be used where ASSE 1016 devices are required. These WATTS valves should never be used to provide "anti-scald" or "anti-chill" service. When installing the Series 1170 valves in a radiant heat application, the components of the radiant heat system must be of materials with a construction capable of withstanding the high limit output temperatures of the heating boiler. If you are uncertain as to the product's adaptability for your application, please consult an authorized representative before installing or using the product.
