RidgebackKing
I currently have a very old water heater in the crawl space (you can almost stand upright) under my house that serves the master bath, laundry room, and a half bath. It's able to serve a couple of concurrent showers but it just will not fill up the big jacuzzi tub. I was thinking a tankless water heater would be a great solution here but I'm not sure if one can be supported.
The breaker is a 30amp double pole with 10/2 wire to the disconnect.
Hot water at tub flows at ~7 gpm.
I do not have gas available.
Do those parameters allow for a tankless water heater capable of maintaining the flow rate or would I need to have an electrician give me an estimate on getting a higher amp connection to the install point, IF it could even be done? Thanks!
