Hi There:
I'm new to this forum, first posting...
A DIY question: I am installing a new hot water heater. It's ready to go, and I am dry-fitting the copper (3/4") piping above.
The nipples on top of the heater specify that no heat should be directly applied, as they have plastic inside. Soldering the pipe separately to a fitting, then screwing it onto the nipple with plumbing tape is not a problem.
However, I will have to solder the pipe past that at some point. I am wondering how close I can solder without getting the nipples too hot and damaging the plastic inside. For example, I need to make a 90-degree turn no more than 10" away from the first connection to the nipple.
Given how hot the copper pipe gets, this still seems awfully close. Questions going through my mind are how to keep the pipe cool? Should I use MAPP gas instead of propane, because it's faster (I now have a cheap propane torch)?
Any advice as to proper minimum distance to solder from the nipples, and how to keep the pipe cool, and whether MAPP should definitely be used, would be appreciated.
Thanks & regards,
Wayne
Thanks & regards,
Wayne
