Dirty toilets - don't jump to conclusions please.
cgilley
Supporting Member
Apr 5, 2023
184
98
North Georgia
Kind of hanging myself out to dry here, but here we go. I have 5 toilets in my house. The house was built in 1989 and has nothing but CVPC or copper for plumbing. The toilets are all 20 to less than 5 years old. Most of the hardware has been replaced multiple times. The toilets may range in age from 20+ to 2 years old. I mention the age because toilet bowl design has changed over the years with the advent of the low water flush units.
I've noticed a significant increase in dirty toilets. I don't mean we forgot to flush, but usually you get a ring around the water level when you don't. What I am seeing are tracks coming down from some of the toilets - mainly the newer ones - and the tracks are patterned after the flow holes up under the rim. I have never seen this on the older toilets. I can go back to the late 60s as a kid and tell you I have never seen this.
Is this a hardware issue? Water quality?
You could do a couple of things, take a sample to your city water dept, for a test, even a pool co would do
Another thing you could do is shut the water off to your toilet flush it tape off the holes under the rim pour vinegar/clr into the hole under the flapper that should fill up the rim of the toilet,let it sit overnite remove everything turn the water on and see what happens
Toilets that get cleaned once a week and flushed when used typically don’t have a problem.
