I know a similar problem has been posted many times here, but mine may be slightly different. I just installed the Delta Trinsic 17 2-handle shower faucet in my existing bathroom (built 1995) using a replacement cartridge recommend by Delta, model RP32104. My friend with considerable building experience, but necessarily plumbing-specific), did the installation with me following the instructions exactly. Everything works fine except Hot and Cold are reversed. I know the common solution is to reverse the orientation of the cartridge, but if I do this it will not fit into the preset notch in the brass valve barrel. Is it possible something else is causing this problem? And yes, the water lines are installed correctly. The previous shower faucet was also made by Delta (1500 Series).
Thanks for your guidance.
