ericblair
My Delta kitchen faucet is leaking, it seems to me, from inside the valve housing. The water can only be seen leaking under the sink not above. I verified that it's not the weighted pull-out faucet connector that's leaking (that sometimes gets loose.)
I've had this faucet for several years so I don't have the model number. It's one of those fancy-looking ones with a copper finish.
Anyway, are the parts generally interchangeable between Delta models, so if I buy a packing and ball assembly it will still fit???
Thanks!
Thanks!
