Curb Stop Valve Access Cleanout
pope_of_chilitown
May 13, 2013
It turns out the plug to the pipe that leads down to the curb stop valve out in front of my house got busted somehow. Now the pipe is plugged with whatever crud made it's way in there so the valve is inaccessible. The only reason I even knew about it was because the city water guys came by and painted the cap and then sent me a letter telling me to clean out the pipe and replace the cap within 30 days or else they would do it (at a cost).
How do I clean this pipe out? I'm not sure how long the pipe is down to the valve. I shined a flashlight down the pipe and all I could see was standing water about two feet down. I thought I might be able to stick a shop vac hose down there but the pipe is too narrow.
How would a plumber clean this out? Would it be costly?
This is a link to a site that shows some of the types of tools you may need. I'm not promoting the site, just giving an example.
http://www.pollardwater.com/pages_product/P515auger.asp
As John said, you probably have to dig it up because it's broken. Get a few quotes from plumbers, at least three. They may need to replace the extension or the whole thing and prices vary on materials and labor. I recommend a plumber because you are dealing with the service and if you have a problem you could end up with a real mess on your hands. Damaging the service or the valve while digging is always a possibility. Chances are it would be more cost effective than having the water company do it and a plumber should have all of the necessary tools to handle it without you purchasing them as well as the materials to do the repair.
If the plumber can clear the box with the auger, repair box covers may be available in your area at supply houses. They have a set screw to hold the top on and inside repair caps are available for larger curb boxes if the break is close enough to grade, but an on site inspection is needed to accurately assess to type of work needed.
John and Caduceus,
Why would it likely need to be dug up? Do you think the mud damaged the valve in some way?
Thanks for your help!
The curb box is just a cover to protect the valve and allow limited access to people who need to get to it. Once the box top or a portion of the shaft is broken, it can be difficult to repair or replace. The simple repair is only in a best case scenario. Without being there to look at it with the wide variety of boxes in the US and also the potential problems that you could run into, the most simple advice for the fix is to dig it up and replace it.
It's one of those "figure it out as you go" problems that an experienced plumber can deal with. I have augered boxes and found shifting in the shaft and the valve isn't even under the box anymore. Once you have a compromise in the box, mother nature takes over and you never know what you will find. Then again you might get lucky and it's all straight and in place and no problems.
Most boxes I've serviced need to be dug up and I'm sure John has had the same experiences. Like I said, you may get lucky but without being right there to see the circumstances we can't be definite. It's a tricky one to nail down to only one answer over the internet. The method of service is improvisational.
I should add that in my area the water company usually owns the box and the valve, but not the service line. I may have only encountered this 20 times in my career with other jurisdictions. John has probably seen more of these situations than I have.
