Toxarch
Active Member
Edit: Sorry, I mean PVC, not CPVC.
Is there no search function on the forum or did I miss it? I know I am SUPPOSED to wait 24 hours. But I'm going to need a shower before then.
I just replaced a gate valve with a brass ball valve. City water from the road and 3/4" valve in the box. Switches to 2" pipe all the way to the house. The old gate valve was a 2" brass that was a water softener bypass. It started leaking the other day when I used it. So I changed it out with a 1-1/4" ball valve since that is the largest the city will put in at the road (for an extra monthly charge). House was built in 1987 but it looks like someone already replaced this valve once before I moved in in 2000.
Anyway, it's been an hour and I'd love to test the system for leaks now before I NEED the water for a shower later. Only leaks I am worried about are the threaded fittings and the disconnects for the water softener.
All slip connections were primered and glued.
threaded connections were done with teflon tape
60 F temperature outside (in the garage)
very low humidity outside
