I need to cut a pex line into and install a cutoff CPVC valve. Why can't I re connect the pex line by using 3/4 cpvc compression fittings on the 3/4 pex line? They seem to fit tight and would be better in my estimation than shark bites. The rubber seals on the compression give a good fit.
jrh
jrh
