I installed a new Rheem wh from Home Depot about 6 weeks ago. I did most of it myself but had a local plumber hard pipe the cold water side. The building inspector came by to inspect and pointed out that there was significant corrosion at the cold water nipple coming out of the wh. The building inspector was not sure what was causing the issue. It looked to me that there was a small leak from where the copper fitting was attached to the nipple. I contacted Rheem and they put new galvanized nipples in the mail.
The plumber came back out and said it was due to it being a cheap Home Depot unit with cheap galvanized nipples and that he believed the water was actually bubbling up from below where the nipple connected to the wh. He said the best course of action would be to get a new unit under warranty since the threads inside the wh itself could be compromised. He believed even if a better material was used that the threads inside the unit itself could be galvanized and a different material nipple could cause an issue.
What sucks is this unit is under the stairs in a condo and is accessed through an opening in a closet just big enough to slide the unit through. Install was a royal pain in the ass. I am trying to avoid pulling this unit at all costs. Does anyone have a strong opinion on what may be causing this and whether another material nipple may help? FYI, I read in multiple places in the manual that applying heat to those connectors can cause permanent damage to different components. I'm pretty sure the plumber did the connections with the copper fitting attached to the nipple.
Pictures are attached for reference. Any advice is greatly appreciated.
