indcoltsfan32
My wife and I built a house approx 5 years ago in central FL. After living in it just after a year we started noticing a huge problem with phorid flies (sewer flies) inside the house. So we had a septic company come out and we found them inside the septic tank and sewer lines (thousands of them). So we had the septic tank pumped and the problem went away for about two weeks but came right back. I am tried everything to get rid of these things to no avail. The only thing I haven't checked so far is a sewer line break/leak. I did alittle research and bought one of those inflatable plugs, stuck it in the clean out and inflated it. Filled up the sewer lines from the tub until the water started coming in from the lowest drain in the house (low shower in master bath). I let that fill up to one of the grout lines in the shower for a reference point and let it sit for approx an hour. Came back in and the water had dropped quite a bit (approx 10 gallons in an hour) and its not leaking past the inflatable plug. Can i assume the water is leaking from a sewer line break?
We have been having a huge issue with these flies for the past 4 years, through out the entire house.
