Dielectric unions were used above my hot water heater with copper on both sides.
I recently purchased this house. The idea probably was to make it easier to replace the hot water heater by having unions present.
Now I see however the unions are corroding. Should I jumper across the unions to create a common ground connection?
If so, how should it be jumpered, above the unions between hot and cold, or connect all 4 points together?
See the attached image. Thanks in advance for the help.
