Hi!
I was putting in some new pipes to run clean water from the water filter to the faucets. As I had to remove some old pipes, there was one place where iron met copper, and as I was unscrewing the iron pipe, the 90 that connected it to the copper turned far enough and broke off the copper fitting that was there. So I replaced all the copper pipes on that side of the wall with PVC, but there is still a copper pipe that runs into the wall, and I don't feel like tearing the walls down to have that replaced. However, the piece that sticks out is really a small tail, the rest are back-to-back soldered joints before the pipe disappears into the wall.
To connect the new PVC pipes to that copper, I put together a compression to IP 90. Now, that was a total failure. First, I used the nut that came with the fitting. That just was leaking profusely. After unsuccessful attempt to cap it (I had a post about that earlier today), I used separate nut and ferrule. I hand tightened it, wrenched it in a little more, and turned the pressure on. That left me with water just spewing out of the joint. I started tightening it until the leaked stopped. And it did stop, but the amount of torque I had to apply to that fitting is far beyond the standard 1/4 turn with a wrench rule (it's probably at least 2 full turns, didn't really count).
My questions is - do I need to think about replacing this with a better connection anytime soon? Should I rather solder, or bite it, and tear town the walls and replace the pipe all together? Here are the pictures of the joint, you can see the amount of exposed pipe, it's condition, and how much do I have to work with here...
Thanks!
Pawel.
Thanks!
Pawel.
