Copper NPT Thread Nicks
dlipter
May 19, 2013
Have some Nibco 604 3/4" copper NPT Male Adapters. Upon close inspection, I see some small nicks in the threaded portion. How perfect must the threads be to prevent leaks? Will the threads cold form and seal, correcting any small thread flaws?
Thanks
If they are small, use some pipe thread sealant and wrench tighten them into a female fitting. Then remove them, use your normal method of thread sealant, and final assembly. Small nicks should be fine if you do this to properly "clean" the threads.
