Have CPVC system in my home and I planning to add bathroom. I want to plumb the new bath using PEX. My question is about how to connect the two PEX lines into my existing CPVC system.
Was planning to add a tee into the 3/4" CPVC lines and then a short section of CPVC, a shut-off, a short section of CPVC and then a CPVC/PEX adapter that would be slip (glued) on one side and barbs (crimp ring) and the other side.
Problem is I am having trouble finding that adapter 3/4"Slip to 3/4" PEX. Anyone know the fitting I need and where to buy it? When I search I find a lot of the Sharkbite type push-in tees but not the glued fitting I planned to use. Not sure about using the push-in solution.
