Compression Ring Damaged hard-to-access Copper Pipe
plumbershark
Oct 5, 2015
5
Hi,
I hope some experienced plumbers are able to help me!
I have a back yard faucet/tap and it has been leaking from behind (Where the faucet/tap connects to the copper pipe). I cannot access the copper pipe as it connects to more piping within the concrete outer wall of the house. The copper pipe extrudes the outer wall by just less than 1 inch.
It appears the leak was due to the Compression Ring/Olive being over-compressed onto the copper pipe and creating a leak. Upon removal of the Compression Ring/Olive, it appears to have nipped/crimped the copper pipe a fair bit, and I only have 1" to work with.
Options(?)
- I have researched Copper Pipe Resizing Tools (Not sure if these only work for bent pipe ends?)
- I don't know if I have room to extend the copper pipe?
I have very limited tools (Just the usual wrench here and there). I don't have a torch or any pipe joining tools or any specialist tools.
I can make some tool purchases, however, I'm just tying to figure out the best way to tackle this! I have done a lot of research and have received very mixed responses. Any input would be great! Thanks!
Images Here
Not really important, but I'm not sure what...
1. The PVC pipe going into the ground is for, it isn't/wasn't connected to anything at all.
2. The PVC pipe connecting to the top of the faucet/tap, maybe the sprinkler system? I have no idea...
I dont have any soldering tools.
Would you recommend I buy the tools, learn how to solder and perform the install or hire somebody?
I read up on Shark Bite connectors, wouldn't this be better?
Personally I would never use a sharkbite or any type of push connector. But if you don't want to learn how to solder and if you don't want to hire a professional to do it correctly then I guess that answers your question. Good luck whatever you choose though.
Thanks for the help. Hiring somebody wasn't in my budget I'm afraid.
In the end I bought a 1/2" Sharkbite connector (Couple to male) and a new faucet (Around $7 each at Home Depot). I cut the end of the crimped pipe off with a cutter before adding the Sharkbite. The guy from Home Deport recommended this approach.
I added some quikrete behind the connector to fill up the hole behind everything, so it doesn't leak from behind into the house. I then used a piece of wood, with a hole in, for the front and to screw the faucet into. If the Sharkbite gives out, at least it'll leak from the front :)
you put a shark bite on a pipe that has been squeezed down/ resized ?
you do know the guy at home debot knows about as much about plumbing as you do. RIGHT?
i mean, if you were standing in the paint aisle, and he wondered thru, he would know about paint also ?
when he goes on break, and returns, is he an electrician ?
not trying to rag you, but, your looking at a leak .
go buy a cheap torch, solder, flux, some pipe and a few fittings
post back,,,give me a pm. i'll walk you thru soldering.
