Recently the condominium complex I live in (in CA) has been dealing with plumbing issues that seem to be stemming from improperly bent copper pipes. There have been a significant number of slab leaks and pin hole leaks. My questions are:
Is there any way to tell whether improper techniques were used to bend a copper pipe?
Is it typical for the pipes under the foundation (for slab leaks) and in the walls (for pin hole leaks)?
Thank You
Thank You
