In my ever continuing Need To Know inquiries here, I need enlightenment concerning tankless water heaters.
This uncertainty actually originated in this thread-
http://www.plumbingforums.com/forum/showthread.php?t=8866
Does the term cold water sandwich refer to the cold water having to be circulated out of the house distribution system (by re-circulation system) before hot water arrives @ the fixture(s) with a tank-less (and isn't this the same as with a tank water heater), or is it the inability of the tank-less to produce instantaneous hot water @ initial start?
I find it hard to accept that once a flow sensor on a tank-less determines flow, that it can instantaneously heat the water, especially electric, to 120F.
Wondering In W(By GOD)V (as are most)
Tankless is often referred to as 'Instantaneous Water Heaters.' Can I expect to have instant hot water at all my faucets and showers?
No. It still takes time to get the water to your faucets, just like it always has. Our heaters provide constant flow of hot water at the desired temperature. To get "instant" hot water, you need a recirculation system.
-TAKAGI
