Hello knowledgeable ones. I would like to install an electric water heater to take care of the domestic hot water supply to my house because the coil in the boiler needs to be replaced and I don't feel that the boiler's initial quality is worth spending $600-$800 to replace the coil. I have a private well as a water supply, not public. To install the new heater, do I simply sever the hot and cold lines going to and from the boiler and connect to the electric heater as per instructions? Do I need to install a thermal expansion tank? I am still a little confused on the whole open/closed water system. I will be installing a vacuum relief valve as per manufacturer's instructions. Should i also install a backflow preventer valve and if so, where? I intend to install a shutoff valve on the cold water inlet side and thought it would be wise to do so on the hotwater side. I'm using a ball valve for both. Any advice other than call a qualified plumber ? Thanks so much for any help you folks can put forth.
