I am looking for a check valve that will allow water to drain out of the un-pressured side of the water line. This drainage I would like to redirect through a garden hose and dump into a work/laundry tub.
I attached a sketch of what I currently have setup.
The t-spigot hose port is only opened once the appliances are completed their regen cycles; at this time the water is drained out of the line. This is all manual, I'd like this to be completed automatic. My hope is that I will reduce the probability of the line freezing as it exits the house.
I've searched and only see these type of drain valves with sprinkler systems.
But the valve assemblies I've seen do not have any adaption to a garden hose port. These just drain into surrounding soil, not my situation.
Any help appreciated.
