jeralmac
Hello community.....
I'm a DIYer that recently installed a Watts #500800 hot water recirc pump with remote fixture check valve. Overall, we were happy with the results, even though the water is really only luke warm (we wanted to do a proper install without the remote check valve but putting in a pex return line isn't an option without tearing up drywall).
After a few weeks of using the new pump, we noticed that we were starting to get hard water staining on our fixtures/tubs/shower etc. We have a Fleck 5600sxt water softener that I installed about 8 years ago that has performed flawlessly until recently. I became suspicious due to the timing of when I installed the recirc pump that it was negatively impacting the softener which when I think about it, make sense as the pump was likely creating back pressure on the water softener.
My question is this: it seems that I need a check valve and based on my research, a spring loaded check valve would be the best solution. However, I've read that spring loaded check valves can take a hit on your overall pressure, which I don't want to sacrifice. Is a spring check valve the best option and if I go up in size to let's say a 1.5" with reducers, will that minimize the pressure impact? Also, can I assume it's best to be installed just after the water softener? Our incoming line is 1" from the well's pressure tank, from there it goes to 3/4 where it feeds our incoming water sediment filter and ultimately the softener and then the water heater (50 gallon tank).
Any advice is hugely appreciated!
