Can't unthread an old fitting sticking out of wall, options? (pics included)
echrist54
Feb 16, 2014
Hi everyone, first off it's my first post here so hello and thanks to everyone.
I'm doing a kitchen project and I've run into a problem. I ended up with the wrong cabinet, and so in order for my dishwasher to fit I had to change the placement. The problem is that after moving the sink, I have a 1.25" copper pipe sticking out of the wall. I tried my pipe-wrench, nothing, tried heating it with my torch, nothing. In order for the dishwasher to be flush with the cabinets I need it to go almost all the way to the wall, and so obviously this pipe is causing an issue. I'm wondering if I can cut the pipe down as close to the fitting as possible and maybe tap new threads into the pipe to make a cleanout, or use some sort of epoxy plug to close it up. Any suggestions would be great, pictures are attached.
Thanks everyone!
http://imgur.com/yZLFLRc
I can't be 100% sure from that picture, but usually the transition from the cast to the copper will be via a threaded fitting. The brass bushing can be peeled out of the cast fitting by cutting out a narrow slice with a reciprocating saw, and then breaking that slice out with a flat screwdriver and a hammer. Then the rest of the brass bushing will roll out of the cast fitting. This can be a 5 or 10 minute operation, or it can be a bit more involved, depending on how badly the threads are corroded.
This worked perfectly! I was able to use a fitting clean out plug and now the dishwasher is flush with the cabinets. Thanks!
