Hi!
First time poster.
I have this bathroom faucet that I would like to remove without destroying it.
It seems as if the valves have a looking threaded nut from the top and once you remove
those you could lower the whole thing and take it out towards the bottom....
if you find a way to remove the faucet with probably another nut under it.
(The mixed water line is threaded on the outside.)
There is no access hole anywhere to unlock something with an Allen key for instance, it looks
as if the whole faucet should just come off when pulled up. (and the revealing a nut that holds
the whole thing together).
It also will not turn at all for a possible 90 degrees unlock mechanism.)
I have pulled and wiggled with considerable force but nothing moves at all.
Any help is appreciated!!!
Eric
First time poster.
Eric
