Hi.
We have a water heater tank from 2009, which has started leaking.
I have opened it, cleaned and checked the magnesium anode.
O-ring seems to seal OK, and there is no visible leak from any external connections/pipes.
The water is seeping slowly out from the blue shell (insulation). So I would think the reason would be that the insulation shell is filled up with water and slowly running over.
It leaks some drops per hour, sometimes a small puddle.
What I find curious is that even though the water holds 60*C / 140*F, and the tank and lid itself is warm to the touch ; the water that is leaking is cold.
The leak is on the opposite side of the water pipe connections. The interior of the tank looks good with only small possible spot of rust.
Any ideas or suggestions for troubleshooting?
