I cant figure out how to remove this mounting piece from the threaded rod. The instructions from the manufacturer (Delta) say to simply remove the piece and pull the faucet off.
As can be seen in the picture, there is a nut screwed onto the threaded rod - however its not a free nut, its part of the ring surrounding the rest of the pipes (all one solid piece). I cant even imagine how this piece could come off because after just 1 rotation, the other pipes passing through the ring would prevent the piece from turning any further.
On the top side, there are no set screws on the faucet and there is no way to remove the faucet assembly without getting this metal ring/nut off.
A basin wrench would not help me here either.. any suggestions?
After a lot of research on the web the only solution i can find to this problem is to somehow grind the piece off, but even if it comes to that does anyone know how this piece was attached to the assembly in the first place? it doesnt make sense to me.
thanks for the help.
