JoeyBradshaw
So many issues to discuss here, stay with me.
Backstory: I installed a water softener several years back. However the softener only works on the left side of the house and the right side is clearly not running through the softener because there is still massive buildup of calcium stains. I confirmed this by turning all the shut-off valves and the bypass valve into their off position and turned on the water in the right side of the house and it still flows... So today I'm trying to correct this but I'm running into multiple issues that I dont understand. When I originally plumbed the softener in there are two 3/4 copper inch lines marked with blue coming out of the concrete in the garage. I cut a 2 inch section out of one, turned the water back on and observed that the one I cut was luckily the only one of the two actually spewing water out so I went ahead and plumbed the softener to it.
First issue is the water heater. One line feeds the heater which is marked as cold (blue), one line comes from its hot outlet and is marked as hot (red), and a third line is the pressure relief pipe. The issues are:
1. The pipe coming out of the hot outlet is chilly to the touch and is wrapped with insulation Why isnt it at least warm or hot?
2. The pipe going into the cold inlet is hot to the touch all the way back to the concrete, 4-5 feet away from the inlet, where it comes out of the floor and is clearly marked as cold (blue). It too is wrapped in insulation. This is clearly the line that feeds into the cold inlet so why is it hot to the touch? It makes no sense at all.
3. The relief pipe goes directly into the concrete to who knows were. Is it possible or normal for the relief pipe to be plumbed right back into the cold water coming in from the street?
Second issue is the right side of the house. Is it common in new home construction for the copper lines to be split under the house to service different sides of the house? Im starting to think that is what was done and not per plan but simply to save money on copper piping If this is the case would an average plumber be able to determine this and what would you estimate the costs be for just confirming this?
Thanks,
Joey
Thanks,
Joey
