I'm replacing a bad flange for the toilet. I wanted to use the oatey compression closet flange with the 3 allen head screws inside :
http://www.oatey.com/products/drains-and-closet-flanges/closet-flanges/replacement-closet-flange
Just wondering how fragile the clay drain pipe is? As long as I don't over tighten it, do I have to worry about it breaking the clay drain pipe? What if the pipe wasn't installed perfectly straight (which I don't believe it is)? The house is on a slab so can't afford to break the clay pipe.
Thank you
Thank you
