Hi, I'm a student in the process of designing a plumbing system. I'm aiming for energy efficiency, and tankless water heaters are supposed to be much more efficient than storage heaters due to the fact they only start when water is flowing. However, one of their drawbacks is that it takes a while for them to bring water up to temperature, leaving the risk of a "cold water sandwich" between the sitting water in the pipes and the soon-to-be-heated water.
What I'd like to know is, would a demand recirculation pump alleviate this? What I envision is that as a person walks into the bathroom, the pump is activated, which in turn activates the tankless heater. Assuming the recirculation loop is short enough, the cold water spot is moved very near to or past the fixture. Does this seem feasible, and has anyone ever installed or encountered something like this? Any other tips to make a tankless water heater work correctly? Or should I just ditch them?
