I've moved over to the Brass Nipples side for water heater connection and will not be installing a dielectric union ever again. However, I've also seen recommendations for stainless-steel nipples, as well as 4" and 6" lengths for these more noble materials. So, what materials and lengths are being used/recommended?
I'm putting a new water heater in our parsonage tomorrow and wanted Twowaxhack's recommendation as he is clearly the expert here, but I think he's blocked me as I can't start a conversation with him, but maybe he'll respond to this post.
In any case, what are the recommendations from some of you other experts?
Also, the church already has purchased a Rheem water heater, and it comes with a set of nipples already installed on the inlet and outlet water connections. I've read that some of the factory installed nipples are hard to remove, but I'm assuming removing them is the thing to do rather than using a brass or stainless coupling. What's the recommendations for them?3.
Thanks all!
Thanks all!
