I bought a 1929 mansion (16,000 sq. ft) at an auction and it is in need of TLC. I have some water pressure issues, leaky pipes and cracked junctions on a 4 floor house (basement + 3 floors). I have been fixing a lot of leaks/holes by replacing the brass piping with copper and getting close. Still, water flow has been spotty at times. Each time I open up the 2nd floor faucet, a bunch of black iron spits out before getting some water out. I haven't been able to see how the pressure is if I open up all the faucets as most have been capped off. 3rd floor shower is not giving great flow - maybe a gallon a minute. The well pump gives me in excess of 50 gallons per minute through 2" pipe. I have a relatively new 120gal pressure tank. Further upstream, the pipes are reduced to 1", 3/4 and then 1/2" to each bedroom. I personally don't think the current plumbing can handle 16 bathrooms of the house - but that is just an "uneducated" guess as I haven't been able to test all of the bathrooms at once
I'm somewhat savvy with construction but I'm kind of way over my head with this project. I was told that I should just start from scratch and pull out all of the plumbing and put in new. It originally scared me because of all of the plaster/mesh/steel ibeams that have to be dealt with but a crew of 6 came and gave me a reasonable quote - I just provide the parts. They work mainly with copper (as they are from NYC) but my friend who owns a big plumbing company told me it's all PEX up where I am (suburbs an hour from NYC). I'm trying to make better sense of this and wondering WHAT SHOULD I DO???? Naturally copper is far more expensive but PEX is easier to work with and easy to fix. Do they even have 2" pex?? I've never had to deal with a complex system as this.
The other alternative they mentioned is that just to fix what is broken, replace all of the valves and "hope" that I get good flow - at 1/10th of the replace price...
Thanks for your advice!!
