I doubt that 8 people will want to take a shower at the same time, so it is a question of demand, and are we assuming that the one electric tank was not adequate for your hot water needs?
How many showers are available? How many GPM flow for the shower heads? Do you want your showers to be very hot (110+degF)? How many GPM can your water system supply? (e.g.- a well pump typically can provide 7-10 GPM). Does everyone shower or do some use a tub? Do you use a jetted tub?
These answers will help to determine how many GPM of hot water is needed and roughly how much storage vs. available recovery rate is needed. Typical electric water heaters can heat about 40 gal./hour, and some can heat up to about 50% more than that, so look at the recovery rate for the heater.
Raising the tank temperature will give more thermal storage, but will constantly lose more heat to the area around the tank.
Two tanks have more surface area than one tank of the same volume, but can have twice the recovery rate of one tank. Residential electric water heaters are no longer available in sizes above 50 gal..
Two electric tanks in series will put most of the work on the first tank, but when that element burns out, you will still have some hot water. Separate tanks for different parts of the house would lose all hot water to their section of house. Recovery rates would also differ.
Two electric tanks installed, including the added electric circuit (assuming that your service has the capacity for another water heater) would cost not that much different than installing a propane-fired tankless heater, depending on location of heater and piping needs. The tankless would be more efficient overall, when there is a large demand in a short time, but it would be sensitive to harsh water conditions, resulting in more maintenance.
