michaelb1478
Hi, I have a residential home question. Where I live the water pressure in the AM is fairly abysmal in the low 30's psi wise. I suspect this is due to sprinkler usage and other factors. I am interested in installing a booster pump to keep a more even household pressure. My question is with my problem being intermittent do I need to take any special precautions in installing. my normal pressure is high 40's low to mid 50's in the afternoon and evening. I have noticed several booster pumps specify an input pressure of no more than 20 psi. Are most pumps able to handle intermittent pressure losses such as i describe? Do I need a pressure control valve before the pump, after the pump, or both? Any other suggestions?
Thanks.
Thanks.
