Boiler system questions
Eyan
Aug 29, 2017
I'm working on an existing commercial hot water heating system that uses two boilers and a storage tank. I've drawn a picture of what I don't understand, note that there are shut off valves and an expansion tank on this system that I did not draw. There is NOT any check valve however with the exception of one possibly built into the pumps.
My first question is, should there be a check valve on the cold water feed right before it gets to the boilers? Other than physics, what's stopping it from circulating back to the mixing valve?
My second question is, shouldn't there be some sort of communication between the two boilers? There isn't any lead / lag or any indication of when to fire other than the aquastat.
Thank you!
yes a boiler is required to have a rpz installed to separate potable and non potable water
yes, the boilers should be controlled to lead /lag so that they wear out at the same time
but not a requirement
no control panel? thats weird
when you say cold water feed, are you referring to make up water?
