Best way to connect ABS to Cast Iron?
brushedred
Jul 19, 2015
I am doing a bathroom renovation. I am using ABS pipes for the drains and have to connect to an inside threaded cast iron coupling/toilet flange.
Before demo, the ABS pipe was glued into the cast iron. It did not leak but I have heard that you aren't supposed to directly connect abs to cast iron.
What would be the best method for this?
I have attached a beautiful paint sketch for you guys :p\
Edit: By the way, there is not room to attach a fernco over the cast iron.
Edit 2: Is it possible to remove the toilet flange without breaking the sanitary tee it is connected to? They are both cast iron.
Hello
View this online video might be it help to fix this problem
[ame]http://www.youtube.com/watch?v=l0-qbe_MEo0[/ame]
