Benefit of insulating pipe
cts001
Jun 6, 2015
9
I am running 2 pex water lines (hot & cold) approximately 50' across my yard to another building on my property. I plan to fully insulate the hot water line but is there a good reason to insulate the underground cold water line while I have the opportunity? The trench will be below the frost line here in NC. Thanks.
i would insulate to protect it from rocks and ground movement. but why pex and not copper. i dont understand this plastic craze that is going around. if copper is installed correctly it will last a long time. you can by soft copper and roll it out
Thanks for the replies. I understand that the cold line should be protected from rocks and stones (although we don't have rocky ground on my property) and I will protect it just case by adding pvc around the pipe. Should I also use styrofoam insulation on the cold water line or Just simply protect it from the rock, etc?
how deep is your frost line?
in florida you can run the water under the grass
mississippi you need to be a foot deep
colorado, 8' deep
as long as your under the frost line your ok, in sandy lome soil, that you say [no rocks] you have
insulate as you come up thru the frost line.
if you are bring the line up thru concrete,,use your insulation as a sleeve..good luck with your project
