hi, first post here, so I guess intro and request for help all in one. A homeowner, usually try to DIY most simple household things. Mechanical aptitude and usually can figure things out.
So I need some help. 13 year old house, we are first owners. Couple of the bathroom sinks started to not hold water with the pop up plug down. I tried the universal plugs you can buy at home depot, etc, they don't fit quite right. I crawled under the sink and figured out how the drain assembly comes apart. I see I have moen parts. The drain is a bit larger diameter than the 1 1/4" universal kits they sell in Home Depot. I called Moen and they said my parts are covered under warranty, so they shipped me out 4 Moen part 10790 "Chrome lavatory waste assembly". It's the drain body, flange, rod, and the oddest part - a totally cast metal drain plug. The drain plug as a loose wiggly chrome cap on it - not meant to take off - with no o-ring. It kinda sorta fits in the flange, but doesn't seat all the way in. Is this some kitting mistake by Moen? or are there drain plugs that don't use O-rings? I haven't installed the thing yet. Just seems odd. All the other part look like the original I took out. Thanks
