Bathroom Sink Drainage Issue/Questions (Photos)
narlycharley
Jan 22, 2018
19
Hello all!
I installed a new vanity and the new sink doesn't line up perfectly with the drain pipe in the wall (the old sink did). The swing from the P trap isn't enough to bring it to center with the drain from the sink, so I need to add a 90 to the left.
I went to Home Depot yesterday to figure out a solution and I forgot that there is already a ABS trap adapter that's glued to the pipe in the wall.
Originally, my plan was to thread a 1-1/2" coupler onto the black ABS adapter in the wall and run a 1-1/2" 90 degree elbow to the left and then out of the elbow a 1-1/2" to 1-1/4" trap adapter for the P trap assembly. This would have been perfect, but the coupler from the ABS was too large, it needs to be 1-1/4 female thread.
I was thinking I could do one of TWO things:
Get a 1-1/4" coupler (female thread to thread onto the ABS, and a smooth female on the other end for the 90 degree 1-1/2" elbow). The only issue is, I don't think they make an "increaser" (opposite of a reducer) to go from 1-1/4" back up to a 1-1/2".
OR, I can get a 1-1/4" threaded coupler to go onto the ABS body in the wall and run a 1-1/4 90 degree elbow off of that. BUT I can't seem to find a 1-1/4 to 1-1/4 trap adapter in a store (haven't looked in person, but nothing online at HD, Lowes, True Value, or Menards). They do sell them online, but I was wanting a solution for TODAY.
Ideas??
Went to HD today and found the freakin' solution. I didn't even think of a 1-1/4" to 1-1/2" adapter.
Here's the finished product. Works and looks great! Surprised that no one has commented on this thread...
That's one way to do it. Could you not have cut the old adapter off and glue an ABS 45° and then the trap adapter
CT< it looks like he has the room to do what you said. That's better than using all those fittings. Just cut fitting off like CT-18 said. Buy a 1 1/2" street 45 degree ell and a hub trap adaptor. Then your p-trap will fit like you want.
Yeah, I definitely could have done it that way. I just wanted it done, and this was the easiest way to do it. I'm unfamiliar with welding ABS to PVC, so I didn't feel comfortable doing it. Plumbing is (for whatever reason) my least favorite trade to practice. Electrical is SO much easier IMO.
I think that if I would have cut the ABS fitting off and done a 45, I would have needed to add in a piece of PVC tubing, which would have been an added expense, as I don't have any on hand.
Either way, it doesn't leak and it's cosmetically fair. I needed to get something done because I did NOT want to use one of those flexible tubes, as they don't seem "correct" to me.
