Bathroom Remodel Advice
harveyshot
Apr 24, 2014
We are doing a complete bathroom gut and will be changing from a tub/shower to shower only. The plan is to install a standard shower head with a rain head on a long shower arm above it. These are the items I'm planning to use:
https://www.amazon.com/dp/B005TG4P2Y/?tag=skimlinks_replacement-20
https://www.amazon.com/dp/B005TG2OG8/?tag=skimlinks_replacement-20
https://www.amazon.com/gp/product/B0040YQ27W/?tag=skimlinks_replacement-20
https://www.amazon.com/dp/B0040YRD48/?tag=skimlinks_replacement-20
http://www.signaturehardware.com/lo...id=GooglePLA&gclid=CJXUk8aS088CFUuXfgodNRgPGQ
Does anyone see any potential problems? I would put the rain head arm through the ceiling but my attic is hands and knees only and the access hole is on the opposite side of the house from the bathroom and I have bad knees. Plus, there is the freezing problem of installing water pipes in the attic.
Thank you.
confused as to what you are doing.
are you installing this shower head on the wall
AND installing a rain head , that is not shown in you links?
or, are you going to use this shower head
but seperate the hand held form the head?
I do not think th hand held will stay in place like you are trying to do
I would buy a shower head that is designed to ceiling mount
He wants to install an overhead shower head with interior supply as a regular overhead shower head entails plumbing changes (above the stall) and has to consider the plumbing will also be in an exterior wall (exposed to freezing temperatures).
Rough Idea-
The shower arm/head you show is perfect (IMO) for what you want to do.
Thanks for the replies. The drawing by Frodo is exactly what I'm planning. I did not include a link to a rain shower head because I thought it was obvious and I haven't picked one out yet. As stated, I'll be using the 36" shower arm for the rain head. It will be mounted on the same wall as the shower head/hand held combo (to avoid running pipe in freezing attic) but probably about 8-10" higher. This is a standard 60" stall and would have preferred a 30" arm for the rain head but the only thing shorter was a 20" or less.
If no one sees a problem with this set up I'm good to go. Thanks again.
