tripolitrx
Hi all, I have a house from the late 50s that has clay sewer pipes under a concrete basement floor. We have what we think is a bow/break in the pipes due to it becoming backed up frequently, and were advised by multiple plumbers to replace with plastic. My Question is are there any regulations about having to put sewer pipes back in the floor of a concrete basement? A lot of the floor would need to be chopped out to get to the pipes, which we simply cannot afford at the moment. My Dad suggested just running the sewer lines above the floor using 3 or 4 inch plastic line by picking up the fall pipe from the toilet, attach and run around the walls and box them over to hide them, then chop through the outer wall and pick up the waste line outside going into our septic.
It seems simple enough and would avoid the hefty labor charges, my concern is if its ok to do this regulation wise, and if it would affect resale value of the property any?
Thank you
Steve
Thank you
Steve
