Basement drain & vent plumbing
coloradooilman
Jan 8, 2015
Hi,
I am new to this forum and so I may be a little slow on replies and getting things uploaded. My dad is finishing the basement in his new house in Weld County, CO and I am helping him. The builder roughed in the bathroom drains for a shower/tub, toilet, sink, and a cleanout (in that order from upstream to downstream on the main line). Due to the layout of the rest of the basement we are considering changing the order so that from upstream to downstream it will go sink, toilet, shower, and then a kitchen sink on the other side of the shower wall. I would utilize the cleanout drain for the shower with a wye so that the cleanout was still accessible. I have attached a drawing of the way I am considering plumbing everything and my biggest question comes in regards to the vents. I would plan to wet vent the toilet through the bathroom sink, and then add an additional wet vent where the kitchen sink would drain into the original drain for the sink. Am I thinking about things correctly?
P.S. - We would remove the P trap in the original shower drain since it will now be used for a sink and install one in the new shower drain.
Thanks,
Matt
Frodo - thanks for your response. Is the option you sent a required setup or just a preferred one? Is there something in particular about the my original drawing that does not work. In order to pipe a new drain into the main line we would have to dig up 15' of concrete and dirt to go from the main to the shower location. If possible, we would like to avoid doing this.
Thanks again, I appreciate your time.
Matt
the shower you drew in, attached to the clean out. it has no vent. it has to have a vent.
heres why. put a straw in a glass of water, put your finger over the end of the straw and pick it up
the liquid stays in the straw.....no vent. take your finger off the straw..VENT
or this. as long as its vented
Matt
from the clean out to theshower drain is 15'
if it is, that will not work at all, the longest your 2'' trap arm can be is 5'
that is from the vent to the trap
In my original drawing I was using the drain from the kitchen sink as a wet vent for the shower. The same way I am using the drain from the bathroom sink as a wet vent for the toilet. Does that not work?
I am aware of the maximum distances a vent can be from the trap. The 15' is the distance the drain would have to run from the shower in order to get to the main line. In other words, all of the drains in the bathroom are offset from the main line by about 15'.
Thanks again.
Oilman,
There is a point when plumbing work goes beyond a DIY project.
With all due respect, your project crossed that line long ago. You really should have a professional Plumber rough in this system for you.
Ok, maybe I am not explaining myself very well. Again, I understand the maximum distances a vent can be from a trap and I am not trying to exceed those in any way. As well, in my very first post I mentioned that the rough-ins were already done by a "professional" plumber who did not take the extra 30 minutes to rough in vents before the slab was poured, so now I am trying to figure out a way to easily and properly vent the system. If I have to bust up concrete then so be it, but I am pretty sure my original drawing works and follows code. If it does not, then please explain to me why it doesn't. The 15' only came into question because Frodo’s first drawing/suggestion was to install a new drain for the shower to the main line instead of utilizing the existing rough in drain like I proposed. in order to do this we would have to break up about 15’ of concrete to get from the shower to the main line.
I have attached another drawing trying to illustrate what I was suggesting in my original drawing but in a different format. In the drawing, the toilet is wet vented through the bathroom sink drain/vent and the shower is wet vented through the kitchen sink drain/vent. Please let me know if this does not work.
Mr Matt, Come on man, in all fairness. you show the main in your drawing directly under the bath piping. you do not show a 15' lateral
the 15' offseted line appeared in a later, updated drawing, that does not match the first one
I would have never said to bust up 15' to get to the main line, there are easier ways of doing it
your quote.
you have submitted 2 different drawings
the first drawing page #2 shows the lav tieing into the main line with a combination.
the second drawing page # 10 shows the lav, the end of the line with a 90 stubbed up...
which which is which????
