I am going to be finishing the basement in a house we just recently purchased and I am trying to figure out how the previous owner roughed this is and how they intended to vent this all.
In the image below the blue lines are what I believe to be the waste lines under the concrete (they did a bad job pouring new concrete over their rough in of the bath). The red lines are waste lines from the floors above running through my joists. The blue Xs are lines running from the waste line above down to the concrete. The red Xs are waste lines from the plumbing above and exit bottom through the roof above and down to the concrete via the blue Xs. The black X is a waste line running from the 2nd floor bath and then runs horizontally in my basement joists to the blue X to exit into the concrete floor.
The second image is what I hope they intended to be the vent line for the bath. You can see this is the line from the black X that runs to the ground via the blue X and then up through the roof via the red X.
Thanks in advance for your help.
