997GTS
We have a water softener and I felt like our water heater tanks don’t last as long and I hear a differing opinion’s. We have two 50 gallon tanks in series with each other and one was manufactured in 2018 and the other one in 2019. In the last couple of weeks I’ve noticed the water isn’t as hot as it used to be and we now have the thermostat set 1/3 of the way between hot and very hot now (just past hot). Before this we had it set exactly on hot.
i’ve heard the anode rod goes bad quickly although I know this isn’t used to heat the water. But I’d like some good opinions here as to whether or not it’s likely the water softener is shortening the life of our water heaters. There are days when we don’t have soft water and the regular water seems harder than usual so I’m wondering if I’m getting a lot of buildup in the tanks prematurely. I’d appreciate any advice. Thank you
