Anode rod material - which should I use?
groston
Nov 22, 2020
19
Michigan
Our house is located in southeast Michigan and has a private well. The water from the well has a total hardness of about 30 grains per gallon, about 2 PPM of iron, and no detectable smell. The water enters the house, passes through a filter, passes through the water softener, and then enters the water heater (a five-year old, gas fired, AO Smith model).
Question: What is the best material to use for the water heater anode rod?
I found several piping errors on Mr Haynes website and sent him notification of the errors.
This was 3 years ago. He’s since corrected the errors.
Not everything you read on the internet is correct.
Edit: If Admin wants proof of my claims I still have the emails. But I will not post them on an open forum.
Many thanks for that valuable information.
