Hello all,
Noticed a couple of weeks ago there is cold air blasting out of the floor drain in the basement. I mean lifting Marilynn Munroes skirt blasting. The whole basement was cold. There is no smell and there was water in the trap but just in case I poured a bucket full of water down it and it didnt make a change. I can see a pipe running of the side of the drain which must be weeping tile. I assume it must be coming from that. I have never noticed it before and I was thinking it was because of the extreme cold winter we have had but my reasoning behind that isnt really clear even to myself, its all I can really think of. It is in the room with the furnace and hot water tank which are both gas. The furnace is hi-efficiency so the intake is plumbed to the outside. The room is open and the house shouldnt be that tight that it is creating a negative pressure. It was built in 1974. I also looked on the roof and cleared snow away from the plumbing stack and it seemed like that it was plugged up a bit so I did the best I could to clear it. I am pretty confident that it is open. We dont have gurgling toilets or anything like that.
I guess my question what would cause a huge amount of air to blast up though the floor drain in the basement like that though the weeping tiles. Maybe I am completely off track with that assumption and it is something else I am not thinking of. Any thoughts would be appreciated. I guess I should just block the thing for now. In some ways that defeats the purpose though in case there is a water leak down there. Let me know. Thanks in advance.
