I am trying to caulk this quarter bend fitting onto a 3" hub pipe. Is there a special tool or technique needed to caulk the lead under the inside bend of the fitting? My shortest caulking tool is too big.
Thank you Frodo. I looked for anything small enough to get into the 1" radius around the hub so I could tap the lead. I ended up using a 1/4" combination wrench. I was able to tap the lead inside, middle, and outside and got a water tight joint.
Over the past seven years I have been experimenting with leaded joints. I had 3" cast iron hubs left over from a plumbing renovation I did back in 2008. I removed all the service weight cast iron pipes and fittings because of damage and rust. I installed ABS in place of the cast iron.
I bought oakum, lead, caulking iron, packing iron, and 3" cast iron pipe. I packed the oakum into the hub and poured melted lead. I used a hot plate and a Bernzomatic Mapp Gas torch to melt the lead. I then used the caulking iron to attempt to get a water tight and gas tight leaded joint. I then placed a Pasco test plug in one end of the pipe and a pressure gauge air leak test assembly in the other end. I pressurized the pipe to 8 psi using nitrogen gas. If there was any leak, I tapped the lead over and over until I got a gas tight joint.
I also learned how to pour a horizontal joint using a runner.
Here is a picture of a hub fitting and cast iron pipe under test after I poured lead and caulked the joint.
