Hello,
I would like to install a whole house filter that requires a drain line. It will backwash with about 7-10 gpm. I have included pictures to show you what the area looks like. I would like suggestions on how to install a drain and if I am able to use this line in my basement. I ideally would want to run a line outside and drain it out in a wooded area or dry well in our back yard but I don’t have the time to lay the line and want to get the water filtered sooner so I will use the septic for a year or two until I can either get a dry well or use the wooded area.
see Pictures for details. In general though
- 2” pvc in basement located 12” from ceiling.
- drain line drains laundry, and upstairs sinks or kitchen sink Before flowing into a larger 4” line
- I believe the builders left a connection spot to use for this very purpose
what parts/sizes would you use to build this drain add on? air gap?
filter will have a 3/4 drain line out I believe possibly 1/2“.
thank you for the suggestions.
