Hi All,
I’m new to this forum and I’m hoping someone can shed some light on an ongoing issues I’ve been having with my hot water tank. The tank is an electric hot water tank, the manufacturer is Giant Inc. History of the issue is as follows:
- Original Tank was under 10 years old and began to leak from bottom.
- A few months prior to the tank leaking, we made a change to some of the plumbing and tapped in the hot water line to a cold line which ran outside to the yard. We did this so we could get warm water outside for the kids to play in. Installed check valve on the cold line so there could be no reverse flow back into the hot line. I do realize now that this is a code violation and will have this changed but I wanted to share this fact as it could be relevant, as the tank problems all started coincidentally after this piping change.
- Original tank was replaced under warranty. This second tank began to leak the evening after it was installed. Water was forming underneath and then a good flow began coming out around the drain valve. Called plumbing company and they replaced the tank for free as the drain valve was faulty.
- The third tank was in service for a couple of months and then began to leak. Leak was again coming from under the tank. It would leak for a day or two then stop, but would be recurring. Plumbing company spoke with the manufacturer who agreed to replace this tank as well. Manufacturer stated there had been ongoing quality issues with their tanks’ welding and believed this was from the bad production batch.
- 4th was installed and again began to leak quite heavily from the bottom. This time I noticed brown water coming out from the bottom which to me indicated that the tank was rusted from the inside, which in itself is very strange considering this was supposed to be a new tank.
- Plumbing company came out to check the house water pressure but could not find anything wrong. I’ve been away for a while so I drained the tank and shut it off before leaving. But not I’m coming back home and need a solution.
Questions:
- Has anyone experienced repeated leaks from new tanks like this? The first issue was a bad drain valve, and the last seemed like rust. The others appear to be due to poor welding.
- Any experience with Giant Inc water tanks? Are they defective or do they have a poor reputation?
- Could tying tht hot water line into the cold be a cause for these issues? It’s far fetched but could cold water be passing through the check valve and back into the hot water tank resulting in some sort of thermal shock to the tank resulting in cracking?
- Are new tanks really “new” ? Or do they just refurbish these and sell them again?
- I’m thinking of reversing the plumbing changes and purchasing a new tank from a different manufacturer. Any recommendations for electric water tanks?
Any insight would be greatly appreciated!
Thanks.
Allan
Questions:
Thanks.
Allan
