Greetings.
My home has always had low pressure. I have city water, but I'm on a dead end section further away from the source. I have tested my outside spigots and only get between 25 and 40 psi. I've had the city here twice and they always say the volume and pressure are OK.
I previously moved to this home, and my other house had a 60+ psi well. This is about half that pressure, and only when no one else on the street is using water.
I noticed that the main line that comes into the house is 3/4 inch. it then connects to the city meter, and immediately drops to a 1/2" pipe. 1/2" pipe then continues to all points in the house.
Would I see any improvement on pressure/volume if i upgraded any of that 1/2" to 3/4"? Perhaps even if I just extended it just a bit closer to the faucets?
Thanks for any assistance on this.
