M mfinkler New Member Joined Feb 19, 2024 Messages 1 Reaction score 0 Location Byron Ga Feb 19, 2024 #1 This plastic gear looking thing is in my outlet pipe between my septic tank and pump tank. My septic is draining slow. Is this a foreign object or something that should be there?
GReynolds929 Professional Professional Joined Jun 16, 2018 Messages 732 Reaction score 389 Location WA Feb 19, 2024 #2 Most likely an outlet baffle filter to keep solids out of the drain field. They need periodic cleaning to clean out the biomat that builds up.
T Twowaxhack Currently in the Lab conducting research Professional Joined Feb 9, 2021 Messages 14,188 Reaction score 6,645 Location United states Feb 19, 2024 #3 If your system backs up and you pull the filter before you pump it down, all that sludge will flow into the drainfield. Stinks too
